- OS: PC 64bit
- SketchUp: 2016-2023
Post
by Fletch » Wed Feb 01, 2012 9:19 pm
(question and idea from original post
here) "How do I render a Transparent Wall, but still make it cast shadows?"
***UPDATED ATTACHED SCENE FOR TWILIGHT V2 - GET IT HERE:
You can download the actual SketchUp scene below.
- Give your wall a thickness of 6 inches/15cm
- apply a color to BOTH SIDES OF the thick wall
- be sure the normals of the wall faces point away from the centerline. (the outside of the wall should face to the exterior, the inside of the wall should face the interior)
- apply the Realistic Glass Template to interior and exterior faces.
- Set IOR for the glass material to 1.1, set Alpha to 1 Set COLOR to “white”.
- Apply Material Template Architectural Glass No Shadow to your Window Glass. Make sure the windows are built with only one face of glass.
- Render with Easy 09
Twilight V1 - download SU7/8 compatible scene in .skp format 610kb
Twilight V1 - download sketchup 8 scene in zip file. 1Mb
![Image](http://twilightrender.com/phpBB3/download/file.php?id=7971)
JGA
- OS: win7 pro 64 bit
- SketchUp: 2015 pro
Post
by JGA » Sat Feb 04, 2012 9:36 pm
Thanks for the demo, I didn't think it could be done in TwiL.
JGA
Ecuadorian
- OS: Windows 7 Pro 64-bit
- SketchUp: 7.1
Post
by Ecuadorian » Sat Jul 14, 2012 12:45 am
This is news for me, too.
![Thumbs Up :^:](./images/smilies/thumbsup.gif)
JGA
Post
by JGA » Tue Sep 13, 2016 6:13 pm
Not at my PC just now, but is "Material Template Architectural Glass No Shadow" going under another name in v2?
JGA
- OS: PC 64bit
Post
by Fletch » Wed Sep 14, 2016 10:12 am
Choose "Architectural Glass">Common, then go to the "advanced" pull-down menu in Twilight Render's Material Editor Dialog and UN-check the "Cast Shadows" check box.
![archglass-noshadow.png](./download/file.php?id=13482&sid=262312734066a2d885836dffed60bf57)
- archglass-noshadow.png (82.41 KiB) Viewed 25718 times
JGA
Post
by JGA » Wed Sep 14, 2016 10:39 am
Thanks for the update.
JGA
JGA
Post
by JGA » Wed Sep 14, 2016 8:09 pm
I tried to have an invisible wall with invisible windows, but I'm having a problem getting rid of the ingoes.
I suppose it's because the wall is solid glass, & I can reduce the wall thickness & edit it out in post pro.
[attachment=0]test.jpg[/attachment]
![Rough test render of a hole in the wall](./download/file.php?id=13485&sid=262312734066a2d885836dffed60bf57)
- Rough test render of a hole in the wall
- test.jpg (214.58 KiB) Viewed 25704 times
JGA
VECO
Post
by VECO » Wed Oct 05, 2016 9:39 pm
Bonjour,
Je viens d'essayer de rendre un plafond invisible pour mon projet déco mais cela ne fonctionne pas. Le soleil passe quand même à travers ?
J'ai joint les vues du modèle sketchup et le rendu.
svp pouvez vous m'aider ?
Merci
![rendu_low+.png](./download/file.php?id=13550&sid=262312734066a2d885836dffed60bf57)
- rendu_low+.png (493.03 KiB) Viewed 25519 times
![vue_dessus_skp.png](./download/file.php?id=13551&sid=262312734066a2d885836dffed60bf57)
- vue_dessus_skp.png (991.06 KiB) Viewed 25519 times
VECO
JGA
Post
by JGA » Thu Oct 06, 2016 8:17 am
Google Translate -
Je pense que votre plafond est une seule face - il doit être un objet "en verre" solide
JGA
VECO
Post
by VECO » Thu Oct 06, 2016 11:57 am
Merci, Oui effectivement je n'avais qu'une face. J'ai rajouté une face et corrigé aussi la matière. (voir vues ci-jointes). C'est ok le soleil ne passe plus à travers le plafond.
Par contre le rendu est "bleu", pas génial même avec Easy09. J'ai appliqué une matière PEINTURE sur les murs mais c'est pas beau. (voir vue jointe).
J'ai donc encore besoin de vos précieux conseils. Merci.
![MODELE SKP nouveaux réglages.png](./download/file.php?id=13554&sid=262312734066a2d885836dffed60bf57)
- MODELE SKP nouveaux réglages.png (1.13 MiB) Viewed 25507 times
![MATERIAU_MURS BLANC.png](./download/file.php?id=13555&sid=262312734066a2d885836dffed60bf57)
- MATERIAU_MURS BLANC.png (697.12 KiB) Viewed 25507 times
![RENDU TW nouveau 09.Easy_46mn34.png](./download/file.php?id=13556&sid=262312734066a2d885836dffed60bf57)
- RENDU TW nouveau 09.Easy_46mn34.png (1.1 MiB) Viewed 25507 times
VECO
