Kitchen "Contest"
- SketchUp: 8
Re: Kitchen "Contest"
Really good Pete... If we have a special guest like that at home, my wife should be very Happy...
Cheers, Fred.
http://www.fredericmoro.com
- SketchUp: 2014
One thing I noticed in this scene, which will increase render time is the way the spot lights components are made...
Fred have applied an Emitting material to a circle shaped mesh, however, this will mean that the emitting surface needs to be divided into several triangles (depending on the number of segments used to make the circle...) and each will need to be calculated during the render...
Images often says more than a thousand words, so here you go... As you'll see, I've placed a pointlight inside the "can"... The only function of the point-light (also known as omni lights) is to light the inside of the "can" to make it look realistic...
Below the point-light I've placed a Spotlight... (hope the purpose of the spotlight is obvious..!? )
The spotlight can easily be replaced by an IES-light...
As an alternative, you can place a small square plane and make it a self-emitter, instead of the point-/omni-light inside the can...
Just make sure that the Emitting plane is either a square or a triangle...! I recommend that you only apply self luminance material to square- or triangular- shapes...
To make a spot light can that render quickly, I personally prefer to make them as follow:A circle will increase the render time, since a circle or a sphere shapes needs to build up substantial numbers of triangular mesh faces and the render time will be analogous to the number of triangles.
Kim Frederik
Twilight Render Support
Kim Frederik
Solo I love your image. DOF looks sweeeeet!! love how easy it is to set up! I like your other version too, fred. Much more abstract and compelling than the original.
Oli
- SketchUp: 8
Thanks Frederick,
I doesn't know about that, cool to know, I will try with yours Tips...
Cheers, Fred.
Here's a quick one rendered in 1 hour using #10...
- Green-kitchen-Frederik.jpg (430.73 KiB) Viewed 16566 times
Kim Frederik
Kim Frederik
- SketchUp: 8
Cool Frederick, and only 1hour. Your new spotlights make the difference, and these eyes too...
Cheers, Fred.
Oohhh yes... I assume that you've already seen the Lights - render times thread I've posted...?fymoro wrote:Your new spotlights make the difference...
Kim Frederik
Kim Frederik
- SketchUp: 8
yes I have seen, and it's your spotlight that I use for my Yellow Submarine...http://twilightrender.com/phpBB3/viewto ... f=16&t=666
Cheers, Fred.
Ooohhh... I'm pleased...fymoro wrote:...and it's your spotlight that I use for my Yellow Submarine...http://twilightrender.com/phpBB3/viewto ... f=16&t=666
Kim Frederik
Kim Frederik
