Inspiring stuff, i especially like the use of SP on the chains, very creative.
Maybe stick a rusty toolbox and some spanners in there?
Old Factory
Re: Old Factory
I don't drink these days as i'm allergic to alcohol.
I breakout in handcuffs!
http://richardobrien.moonfruit.com/
Re: Old Factory
Next round. I added the pipe and valve on the left. I tried replacing the chain links but they ended up to thin. The next step is to texture the pipe on the floor. I ended up doing the UV for it in a separate application. It's in the queue for rendering. After that, I think I'll go for some more lighting, some narrow strips of light, as from a skylight.
- factory.png (475.91 KiB) Viewed 9529 times
Re: Old Factory
Textured the pipe, let it render for 12 hours.
- factory.png (453.52 KiB) Viewed 9484 times
Re: Old Factory
And a bit more interesting lighting...
- factory.png (476.64 KiB) Viewed 9445 times
Re: Old Factory
Chris...
Can't you give a short tutorial on how you've managed to texture the pipes that well...
Everybody knows that SU is lacking UV-mapping, but you seem to have managed it very well...
Kim Frederik
Twilight Render Support
Kim Frederik
Re: Old Factory
I presume it was UVmapped in Wings3D, Chris appears to be an expert in modeling with this program... but I of course am not 100% sure.
Re: Old Factory
Half yes, half no. Wings3D does have some great UV mapping tools, so it's always a good suggestion. The problem is getting the geometry out of SU (unless you have pro). I use the obj importer ruby (I think by TIG?) to get the geometry back into SketchUp (unless, I suppose, you have pro).
Users browsing this forum: No registered users and 27 guests
