Color Mixing
Color Mixing
You know those pictures you see of 3 colored circles of light overlapping to make white in the center? Well I thought it would be fun to duplicate that with Twilight. I just had to make sure the lights were perfectly red, green, and blue(RGB values 255,0,0; 0,255,0; 0,0,255; respectively), and it worked perfectly! Model is attached if anyone wants to play with it.
- Color Mixing Easy07.jpg (58.79 KiB) Viewed 28413 times
- Color mixing Twilight.skp
- (81.86 KiB) Downloaded 1361 times
-Marcus
Re: Color Mixing
great idea! I love these technical explorations.
You can actually split a light beam into its colors in Twilight... if you set up a proper room/prism, etc.
Re: Color Mixing
well, I'm sure Oli will show us how it's done.
Re: Color Mixing
Chris showed how it's done many moons ago...Fletch wrote:You can actually split a light beam into its colors in Twilight... if you set up a proper room/prism, etc....
...well, I'm sure Oli will show us how it's done.
Check out the Optics thread, where you also have some render ready scenes to download...
Re: Color Mixing
Ooo.. great find, Frederik!
I knew it was around here somewhere.
Leave it up to Chris to knock this one out of the park.
*ps - scene moved to "Freebies" section for easy finding later.
Thanks for sharing, Dozer!
