I tinker with Sketchup from time to time. I consider myself an intermediate user. I just do this as a hobby/time filler. I decided I would try Twilight to learn some basic rendering.
I'm working on a project that has to do with a hobby of mine. I want to render it to get a better idea of how it would work before I actually build it. I've come up with a much simplified version of the actual project and modeled it in Sketchup 2018. If I can figure out how to get this render to turn out good, then I should be able to apply that to the more complicated version.
It is supposed to be a Box covered in black velvet. The front is glass and the back is open. Inside is a glass that is supposed to be slightly tinted and show the reflection of the light bulb in front of it when turned on. The bulb should be a 100w-150w incandescent or the equivalent led with clear or smoky glass bulb. It is meant to be used in a room that is mostly dark with maybe a little ambient light. I want it to look as close as it can to what the actual device would look. I would like to know what I did wrong and what I did right (if anything).
Sketchup File https://www.dropbox.com/s/levhgn233e8t8 ... x.skp?dl=0
Help Me Learn with This Unusual Project
- Capture.JPG (106.5 KiB) Viewed 2609 times
- Capture2.JPG (33.28 KiB) Viewed 2609 times
- Capture3.JPG (32.11 KiB) Viewed 2609 times
Re: Help Me Learn with This Unusual Project
Hello Mich81,
Sorry for late reply, somehow this question was lost in the shuffle.
- we changed the glass materials, using only templates - see attached scene.
- we changed environment and turned off sun. - see attached scene.
- we deleted your light bulb and inserted png image of bulb (back-to-back copies, actually) setting material to emitter/fake emitter 800 Lumens.
- we rendered with Medium+ render setting.
- we rendered with Easy09 render setting.
- we set image Tone Mapping to 1.5 exposure in render dialog. This can easily be set to exposure 2.0
- we placed objects in front and behind to help understand what's happening with relfections/refractions in this scene.
- Light box-TWLSupport_Scene 2-Medium+.jpg (235 KiB) Viewed 2522 times
- Light box-TWLSupport_Scene 2-easy09.jpg (317.91 KiB) Viewed 2522 times
Users browsing this forum: Ahrefs [Bot] and 26 guests
