Skatter objects will not render
I've done everything I know how to do, but I can't get my Skatter objects to render. I am running Twilight V 2.11.1 Professional and Sketchup 2018 Professional, Windows 64-bit. The only thing I haven't done, which I'm assuming is the reason my Skatter objects won't render, is that I haven't gone into "Advanced Render Settings" and turned on Skatter. I keep reading that this needs to be done but I CAN'T FIND THE ADVANCED RENDER SETTINGS for Twilight! I don't think I'm that dumb, but maybe I am. Please someone, anyone, help me find them! Or is there something else going on?
Re: Skatter objects will not render
Skatter with Twilight Render Tutorial
Subject: Create a Lush Grass Lawn with Skatter Plugin #Skatter
Subject: Skatter objects not visible render
I CAN'T FIND THE ADVANCED RENDER SETTINGS for Twilight! ...Please someone, anyone, help me find them!
- Open Twilight Render Dialog to start your rendering.
- Go to "Settings" pull-down menu inside this dialog box.
- Choose "Advanced Render Settings"
- Make sure "Enable Skatter Rendering" is checked.
Thank you for you help, but the "Settings" pull-down has only three choices: 1. Multi-threading, 2. Section cut rendering, 3. Save method. "Advanced Render Settings" is not an option.
Are you using Hobby or Pro? Enable Skatter rendering is a Pro only feature.
I'm using Pro.
Install Latest Version from here, and try looking again for the Skatter rendering option..
Note: Twilight Render V2 Professional users, go here to automatically upgrade your account.
Want access to the goodies? If your username is in orange or blue on this forum, you already have access to the Red Carpet forum section.
I still don't have any options under "Settings" other than: Multi-Threading, Section Cut Rendering and Save Method. What am I missing!!!???
Is you Pro installation activated? Sometimes when Windows undergoes a major update, your license will become unactivated. You can check it by going to the Twilight Render V2 Options window and clicking on 'License'. If your install is activated, it is pretty obvious (it says something like "Congratulations, your install of TWR Pro is activated"). If not, you will need to reactivate it (which takes about 30 seconds as long as you have your product id handy).
Users browsing this forum: No registered users and 53 guests
