Purple haze on image when rendered
- SketchUp: Pro 2018
Im trying to render a scene and I end up with a purple haze on some textured surfaces. I checked faces and have reversed several but that cleared up some of the purple but not all of it. Only happens at certain viewing angles.
Re: Purple haze on image when rendered
it's blue - it's from the environment lighting - the blue sky is reflecting in the surfaces.
This is from the physical sky - and is realistic to life - blue light is actually cast by a blue sky onto objects in the real world.
You can modify this either:
1 in the rendering window:
Post-Process:
Temp:
Temperature Adjust:
Set "Desired" color lower by increments of 100
2 in post pro
Adjust warmth of image using photo editor
3 Change environment lighting to HDR spherical sky
Choose "Spherical Sky" and use a spherical sky image that does not cast color.
Post-Process:
Temp:
Temperature Adjust:
2 in post pro
Users browsing this forum: No registered users and 21 guests
