Hi there, hope you remember me, i'm your old user, from begining i use TWL render. so i had stop period and now i continue work for new project wich will be poste here (and on your main page i hope ) okey, i have some problem about rendering. when i push start button, after some minutes it says that render is failed. can you help me and give some suggestions? what may be the problem?
model is big size with some detailed places (its urban style, night scene with lights)
render failed
- SketchUp: Sketchup 2020
Re: render failed
What version of SketchUp? What render method?
Re: render failed
most likely you have low RAM.
restart the computer, open only SketchUP, and render on Easy09
Re: render failed
i use SU 2017 and latest TWL version (hobby)
render was working well but after continue modeiling, save and restart it dont works anymore.
ah as i see its about slow RAM aah, that will be new good render, okey thanks i will continue it in future, thanks again
Re: render failed
If RAM is low:
purge the model
use SketchUp extension "purgeall.rb"
If you are using high resolution textures, replace them with half resolution textures.
purge the model
Re: render failed
Thanks Fletch
Users browsing this forum: Bing [Bot] and 44 guests
