Page 2 of 4
Re: Question to Fletch About Volumetric Light Beam
Posted: Fri Jan 11, 2019 11:35 pm
by Audiologist
Hi SpookyChick, ya I did read the thread that you point out.
- Screen Shot 2019-01-12 at 7.32.28 AM.png (67.55 KiB) Viewed 7366 times
Wasn't really understand this correctly before, now I got it. Thanks man.
Des
Posted: Fri Jan 11, 2019 11:57 pm
by SpookyChick
You're very welcome, Des. I'm glad I could help. You'll find that a fair number of the members here are happy to answer questions, or at least point people to the right threads. Between Fletch and a couple of the regulars here, I managed to survive my first years with TW Render, so it's nice to give back to the community, even if it's just paying forward by helping a new person.
Have a great day!.
Posted: Sat Jan 12, 2019 12:11 am
by Audiologist
SpookyChick,
you did helped a lot. Thanks again.
Des
Posted: Sat Jan 12, 2019 1:22 pm
Audiologist wrote: ↑Fri Jan 11, 2019 11:31 pm
To SpookyChick & Fletch
Bingo!!!!!
Now, how do I add "GOBO" to that beam?
choose your spot light open the Twilight lighting dialog and change the light type to "projector" and insert your image of a gobo into that projector light.
Posted: Sat Jan 12, 2019 7:59 pm
by Audiologist
Thanks Fletch, I"ll try and get back to you.
Des
Posted: Tue Jan 15, 2019 8:50 pm
by Audiologist
Hi Fletch. So, here is what I did.
In the scene, no other objects but only the light, it looks OK.
- Gobo Test 02.jpg (45.62 KiB) Viewed 7328 times
But the projector light is way too dark compared to a spot.
Here I added a stage. and here is the problem.
- Test 04.jpg (118.4 KiB) Viewed 7328 times
The light beam seems not as smooth as with only the light source in the scene. (Yellow box)
and the beam that suppose to be visible is missing on the stage part. (Red box)
I selected the stage material as Textile/Carpet.
- Screen Shot 2019-01-16 at 4.35.23 AM.png (200.8 KiB) Viewed 7328 times
Posted: Wed Jan 16, 2019 7:55 pm
This will be difficult to diagnose without the file.
Posted: Fri Jan 18, 2019 4:00 pm
by Audiologist
My file size is big, about 15MB. Can't attach it here. Even I cut things a lot, left only the stage and the light source, it's about 5.3 MB.
Posted: Fri Jan 18, 2019 7:41 pm
Purge the file of unused components and materials.
You can use a file sharing service to post a link.
Posted: Sat Jan 19, 2019 4:23 pm
by Audiologist
Hi Fletch.
Here is a second render, look at the stage part and the speakers part (with red circles and red rectangle). Light beams still missing when passing through the stage and the speakers.
- Light Beam Test copy.jpg (366.48 KiB) Viewed 7292 times
And this:
- Test 05 copy.jpg (173.3 KiB) Viewed 7292 times
When I look at a different angle, the light beams looks like they were "Behind" the stage and speakers. Which then I think, there is no options as bring selected objects to front or behind in Sketchup. And I was actually create the stage and speakers first, then I create light sources. So the stage and speakers came before the lights. Which I think this is maybe the reasn the light beams were "Behind" the stage and speakers.
I haven't try with a new drawing, but I will try this later. With lights come before objects in Sketchup.
Des
