Exploration render hangs with section cut 2019
pbacot
OS: MacOSXMojave
SketchUp: 2019
Re: Exploration render hangs with section cut 2019
Post by pbacot » Fri Feb 22, 2019 4:31 am
I installed the version linked in the announcement post that is supposed to be 2.11 but it still shows 2.12.8 in SketchUp.
Post by Chris » Fri Feb 22, 2019 7:22 pm
Initially we had backed the "official" release of MacOS to 2.11. After rebuilding with an older framework we re-released the "offical" version as 2.12, with a note that if you encounter problems, try 2.11.
The links for 2.11:
Pro: https://www.twilightrender.com/public_d ... V2_Pro.rbz
Hobby: https://www.twilightrender.com/public_d ... _Hobby.rbz
Let us know if 2.11 works better for you. Most people who encountered problems did not have any problems with 2.11. I am curious if the Section Plane issue is fixed in 2.11 (because there is absolutely no reason why it should be!).
pbacot
OS: MacOSXMojave
SketchUp: 2019
Post by pbacot » Fri Feb 22, 2019 9:04 pm
Thanks. I'll try it!
Post by Chris » Wed Mar 06, 2019 3:34 pm
We have an update (2.12.15) that we would like you to try (anyone who is encountering Mojave related problems).
Pro: https://twilightrender.com/public_data/ ... V2_Pro.rbz
Hobby: https://twilightrender.com/public_data/ ... _Hobby.rbz
This should fix the section cut issue. The problem is related to the SketchUp api that is provided for plugins. A bug report has been filed with SketchUp. Hopefully we will see a fix in the future. In the meantime, TWR was modified so that all Section Cuts are considered "active". This means you can't deactivate a Section Cut, they will all render. A workaround is to place a Section Cut on a layer and hide that layer.
Post by Chris » Fri Mar 08, 2019 11:32 pm
Ok, let's try this again.
Hopefully this fix (2.12.15) should resolve the section cut issues as well as any secondary UI problems.
Users browsing this forum: Google [Bot] and 11 guests
