indoor sconce with emitter
I tried indoor Sconce double sym from the light pack. I notice it has a light emitter material on curved surface, as opposed to your recommendation.. Also there are double walls with emitter pointing in. I supposed this is for the proper effect of the material.
I found this too bright, using easy O9 for a bathroom scene. Seemed to be burning a hole in the wall but not casting far.
How do you adjust the emitter in the deep editor? I ended up applying an emitter in the template editor. It's similar but your original light seemed to have a variation in the light tube which looked realistic or interesting anyway.
By the way, your tutorials are the best!
Re: indoor sconce with emitter
Did you download this pack?
Light Components for Twilight V2
What are your exposure settings when rendering with Easy 09? The Indoor Sconce Double Sym looks ok to me below.
See below, using Simple: exposure 1, gamma 1.
Applying an emitter to curved surfaces (or not applying) is a general recommendation, not a "hard rule". If it looks good and works, then there's no reason it should not be done. It simply increases render times, but it's not otherwise hurting anything.
The emitter you are seeing in the Deep Editor is actually in the "Fog" channel, and gives the glass the subsurface scattering effect of light scattering through and lighting up the frosted glass.
- BarcelonaPavilion_MiesVanDerRohe_LightTest_Interior-Easy09.jpg (257.3 KiB) Viewed 6728 times
- BarcelonaPavilion_MiesVanDerRohe_LightTest_Interior-Med4.jpg (276.24 KiB) Viewed 6728 times
The Light Components seem to look quite good, to me. Can you show me an image and point out more specifically the challenge so we can better assist?
Here are some of the other sconces, they also seem to look good.
If the light is too bright - and you find you are boosting the exposure, then lower the power of the lights (set them using Lumens is most precise, or cut the wattage number in half) so that when you boost the exposure it doesn't blow out the lights.
- BarcelonaPavilion_MiesVanDerRohe_LightTest_Interior-Easy09b.jpg (201.85 KiB) Viewed 6725 times
I might have saved a first test but I don't have all the settings. I'll run with the original fixture for comparison.
I adjust lights and (emitter materials in template editor). I just don't know where to adjust an emitter in the deep editor.
BTW in the template editor, what does it mean "total output" as opposed to "per square meter". Total output of what? All the surfaces in the model with that material?
Yes, that's exactly what it means. Though if you have your geometry in a component, I think it treats it as total surface within that component rather than the entire model.
If you want to convert the lamp glass called "Diffuser_Sconce_Double" to be a simple emitter, I would just convert it to the template "Emit" material, as it's more convenient to adjust there. You would do better, if you want to keep the Diffuser Glass material easily editable without going to the deep editor, to convert the lampshade glass of the component by applying the Twilight Material Template>Lamp Glass>Gloss (will be reflective like glass when you turn off the light inside) or Matte (doesn't have the reflectivity of Gloss template, acts more like a sandblasted glass surface) But it's best not to change the glass at all as it works well the way it is, and the Template>Lamp Glass>Glass does not look/act the same as the Deep Material. See attached. Simply change the watts of the lights inside to be 6 instead of default 13. Copy the light bulbs around inside of the component if you want more evenly distributed light inside of the glass tubes.pbacot wrote: ↑Thu Mar 21, 2019 7:30 pm I adjust lights and (emitter materials in template editor). I just don't know where to adjust an emitter in the deep editor.
If you open the Indoor_Sconce_DoubleSym lampshade/glass material called "Diffuser_Sconce_Double" in the Deep Editor you will find the "emitter" under "Fog>Simple Fog Interior">Emit Intensity is set to 1.000
It is not actually emitting visible light unless it's hit with light from the point lights inside of the component. So no need to change it.
- Low+ Render Setting
- 13-watts.jpg (66.1 KiB) Viewed 6702 times
- 6-watts.jpg (59.68 KiB) Viewed 6702 times
- 0-watts.jpg (32 KiB) Viewed 6702 times
Here it is with 12 point light "bulbs" at 6 watts each
- 6-watts-12bulbs.jpg (62.76 KiB) Viewed 6698 times
Thanks Fletch! I didn't see this last bit you posted. I'll have to study it.
