Page 1 of 2
EXTENSION NO RUN HELP
Posted: Fri Apr 19, 2019 3:29 pm
by jules200
Re: EXTENSION NO RUN HELP
Posted: Sat Apr 20, 2019 7:16 pm
You are using an old version. Please download and install the latest version.
Posted: Sat May 18, 2019 2:44 am
by jules200
I loaded your last version and I have the same problem
Posted: Mon May 20, 2019 2:31 pm
Please post a new screenshot of the error.
Posted: Wed May 29, 2019 5:24 am
by jules200
Posted: Thu May 30, 2019 9:21 am
by jules200
Any solutions ?
Thanx
Posted: Sat Jun 01, 2019 7:20 pm
Testing with the latest MacOS Mojave and the latest version of SketchUp, we encounter no problems.
Either there is a problem because you installed the wrong version previously and did not fully remove it before installing the new version, or there is a conflict with another plugin.
The first thing I would try is to completely delete anything to do with Twilight Render in your SketchUp plugins folder. It will be located at User/Library/Application Support/SketchUp 2019/SketchUp/Plugins. Find the files and folders with twilight in the name and delete them. Then reinstall the latest version downloaded from our website.
If that continues to fail, try disabling all other plugins, and restarting SketchUp.
Posted: Mon Jun 03, 2019 7:54 am
by jules200
Sorry Chris,
I looked for all the files or elements Twilight, I at all cleared, I uninstalled sketchup. you can see below, I still have the same problem and I really need a fast rendering software.
Posted: Mon Jun 03, 2019 2:12 pm
I think that is the wrong place. As I understand it, MacOS has two 'Library' directories. One is system wide and the other is per user. You want the "per user" Library. Typically this is reached by opening Finder, and then from the Go menu, choose "Go to folder" and enter ~/Library
From there you can reach Application Support/SketchUp 2019/SketchUp/Plugins.
Try cleaning out all the twilight related stuff there. Uninstalling SketchUp won't do anything because it doesn't delete that old data.
If it still doesn't work, let us know.
Posted: Tue Jun 04, 2019 4:14 am
by jules200
doesn't work
