Faceting
Re: Faceting
make sure it is within group or component and smoothed (I'm guessing it already is, but I have to be sure)
Update to latest version of Twilight to make sure. I think there may have been this bug in one release.
Re: Faceting
Thank you. I grouped and also smoothed and grouped (exploded smoothed and grouped- actually saved the component and worked on it in a separate file because I wanted to avoid having to replace all the components in the file). I'll check for updates.
Re: Faceting
pbacot,
Did this issue get resolved?
Re: Faceting
Sorry, no. I went along . I tried grouping and regrouping re-softening. The model has been used many times before. Maybe that car is too old! Certainly could use something more high-end. It's only a part that seems to look bad in the rendering.
I saw this in another model for a vase, and I couldn't stop it there either. So it made me curious.
I have version 2.12.15 for Mac, and we were re-installing back and forth (i.e. going to older versions) trying to solve Mac problems, so I was unsure whether I should be installing something newer before checking.
Peter
Peter
Re: Faceting
Are you using SketchUp 2019?
Re: Faceting
Seem to recall a Twilight user posting about this on the SketchUp Forums. They found a work around by checking the "weld vertices" box in the Advanced tab of Twilight"s Material Editor if memory serves me right. Worth a try......
Re: Faceting
This may (probably) be a problem with SketchUp 2019 for MacOS. It's part of the bundle of problems we are seeing with SU2019 MacOS. We are working with SketchUp to get it resolved; we don't yet have an update that can be used to fix those problems.
Re: Faceting
Thanks! I look forward to seeing how it turns out!
