Hi there,
I'm having some issues with blocks showing up very choppy, see below.
Everything except the circular table tops is a block. The table tops look fine, as do the blocks if I were to explode them, however I am working on a rather large project and exploding every single block would not only take me a long time but it would be more difficult for me to work on my model.
I really hope someone can help me with this, it's a persistent issue I've been having.
Thanks!
Blocks showing up choppy in renderings
- i8w0gFL.jpg (525.86 KiB) Viewed 3422 times
Re: Blocks showing up choppy in renderings
Hello Modestamoeba,
Sorry to hear of your troubles. The image you show is very strange.
Please be sure you have gone through the "preflight checklist" for rendering and that you have watched our video tutorials (sink link in my signature below).
- Are you on a Mac?
- Which OS are you using exactly?
- May I presume that by saying "Block" you are using AutoCAD terminology for what SketchUp calls a "Component"?
You are right, you should not be needing to explode your components (blocks that are copied repeatedly throughout the scene). - Were these components created within an external program and then imported into SketchUp? If so, which program?
- Does this happen on all different render settings?
- Is your model located a long distance from the model's 0,0 global central axis?
