Adding point light results in render of only background
So I am VERY new to sketchup and extensions to add light sources. I learn quickly and really hit the ground running using the natural sunlight in sketchup. However, when I have tried to introduce lights to my scenes with twilight render, every time I render the result is just the scene's background. Adding a point light makes everything disappear in any render. I have tried to search this problem here in the forums and in the advanced search. I've been studying tutorials and though I follow the same steps in adding lights, any light that isn't sunlight ruins the render. I'm hoping someone here knows what I'm doing wrong or what utterly simple setting I know nothing about that is tripping me up.
- I'm playing with an outdoor night scene and I have managed to use the sun settings to get a decent moonlight effect.
- PGmoonlightTest.jpg (159.14 KiB) Viewed 3496 times
- But this is the result the moment I add a single point light. Just the background renders.
- PGpointlightrender.jpg (6.28 KiB) Viewed 3496 times
Re: Adding point light results in render of only background
- It's possible that you have your light object selected and are rendering only the light object and nothing of your geometry. (you may have disabled notification of the warning that pops up asking if you wish to render only the selected object)
- It's possible you have set your "update geometry" to "none" it should be set to "all".
- It's possible there's a glitch from an older version of Twilight Render - please be sure you are using the very latest version only downloaded from our downloads page on our website.
- It's possible there is a vray component or some strange image file in your scene that are causing a glitch.
Subject: I see the sky when I render
