hi, im just start using twilight render for some projetcs parthner, and i have some issues tryng to render at specific resolution.
the problema is while rendering at 630x400 in order to match with panel view plus 1000 that use these res. in fact it wont match and, im not designer or profesional but i dont know what the problem can be. the file is to short for P.V.P 1000, obiouly it wont match and expand the image may compromise quality. how me i can render at those proper resolution. i try reduce the laptop screen resolution, but i dont know it is the problem. a newbie user sorry and thx for some halp !!
unmatch resolution on panel view
Re: unmatch resolution on panel view
uncheck box in render dialog "fit to view proportions" which forces the rendering to match SketchUp's view.
- screencap.JPG (25 KiB) Viewed 4067 times
Hi Fletch. thank you for your reply. but humm ,
there would be a way to make the resolutions fit ? cause i have some days tryin many options and fall in found some help. may be an option through sketchup, another extencion. in any case my part is only half of a job and I am unaware of the specifications for the consequent job. any help can help. thx
- specific file, it wont match on Panel View plus 1000 (630x400) res.
- PanqueProyectPryd_Scene 1AA4.jpg (174.82 KiB) Viewed 4063 times
Are you using pirated software?
Users browsing this forum: Google [Bot] and 56 guests
