Hello everybody,
I would like to insert lights in a lights string.
Would someone can help me for choosing the right light.
I have chosen glass materials for the balls, but not all the balls have kept the material.
Something wrong for sure.
Many thanks in advance for your help.
Chantal
IES files
IES files
- test LAMPE SAPIN.jpg (486.87 KiB) Viewed 6005 times
Re: IES files
Any of the larger lighting manufacturers provide the IES file with their light fixtures on the webpage.
Visa Lighting is an example
Meanwhile, several IES files are provided with their light fixtures here on the forum:
Subject: 5 IES Spotlight effects (including SU model and IES files)
For Pro Users - (we are having a 50% off sale for Black Friday) you should definitely get the Lighting Components ready-made for Twilight.
Subject: Light Components for Twilight V2
3rd party tool:
A Tool for IES lights called "GE Light*Beams 3.0" is for download here:
https://products.currentbyge.com/lighting-tools
Here are the free components (not IES, sorry) to help people learn to create their own light fixtures.
Subject: Can Light and 2x2 or 2x4 Standard Ceilight Light Components
Fletch wrote: ↑Tue Feb 08, 2011 11:27 am Some say this program is the best/well programmed free IES viewer/converter
http://www.photometricviewer.com/
3rd party tool:
Re: IES files
Hello Chantal,
Regarding the light string - you will need to accurately model the lights, it's not as simply as a sphere with glass applied. A light bulb is very thin glass, so therefore your glass will not act correctly.
On top of that, light bulbs technically make like from a light emitting surface of some sort - such as the filament of an incandescent bulb or an LED.
There are several techniques for achieving the look you are after. But placing a light object inside a glass sphere will result in exactly what you are showing in your example image, and not result in realistic-appearing results.
The easiest way (my lazy way) is to simply paint the sphere with a light emitting material and apply the light emitter template - set to fake so that it renders very quickly in Easy 1-7 settings, but renders properly in Easy 09 render setting.
Now your light bulb inside of the sphere will produce the light for the Easy1-7 render setting.
There are several other ways of doing this as well. But this is the easiest.
Re: IES files
quick test scene attached demonstrating some possibilities to get you started.
- christmas-light-string.skp
- (314.32 KiB) Downloaded 486 times
- EASY 04 Rendering setting
- christmaslights-Easy04.jpg (52.87 KiB) Viewed 5995 times
- EASY 09 Rendering setting
- christmaslights-easy09.jpg (118.21 KiB) Viewed 5995 times
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 24 guests
