Good Morning,
I need to render this project, and I am worried because, since I put vegetation, I cannot render anymore.
However the render preview is ok, but nothing else.
I hope someone can help me
And my sketchup file is too big, I cannot even send it ....
HELP ! - RENDERING crashes Sketchup
- Capture hollywood.PNG (2.16 MiB) Viewed 7177 times
Re: HELP ! - RENDERING crashes Sketchup
If the Exploration Render is able to render the scene, there is likely nothing wrong with the scene itself. The most probable explanation is running out of memory.
What render method are you using? Have you tried using a different render method? Do you have any light emitting materials? How much memory do you have on your computer? Have you checked your memory usage while attempting a render?
Use Easy08 Render setting, or Easy09. Easy 08 is fast for exteriors with only sun/sky lighting.
Hello again and again,
Here is my computer (French version) details :
Processeur AMD Ryzen 5 2600 6x 3.4 GHz 16 Go DDR4 2400 MHz Disque dur 1 To Toshiba
Carte mère MSI A320M Windows 10 64 Bits Français
Carte graphique NVIDIA GeForce RTX2060 6 Go GDDR6 Alimentation 600 Watt Tour gaming Hunter
Megaport offre 24 mois de garantie sur tous les systèmes PC.
Windows 10 64bits
I am planning to custom it with SSD and 32 Go RAM
What do you think ?
Regarding the craches of Sketchup, it did happen yesterday when I installed "SKATTER".
Looking for the reasons of my crashes, I have now uninstalled Skatter.
Until now I have tried Easy 8.
Windows 10 64bits
What do you think ?
Were you able to isolate the crash?
Were you able to share the scene with us for diagnosis?
SKETCHUP TIP: To improve view performance speed when viewing plants/vegetation in SketchUp - disable Edge Profiles.
(I always have Profiles disabled by default)
The computer specifications seem very good.
Oddly, I may suggest you increase the resolution of your test renderings, perhaps smaller test renderings are some sort of problem for an unknown reason?
Another idea : In Render Dialog, find the settings and reduce number of threads. Perhaps something is hanging up with all the threads (just guessing without scene to test)
Users browsing this forum: No registered users and 24 guests
