Fog in Twilight render
Posted: Fri May 22, 2020 11:36 am
by GiorgiMelkadze3DArt
Hello, i finished work my last model and i want to add fog (with depth render). i use Sketchup fog distanse change to get realistic fog for my render, but everytime after depth render using, i get same result. for example, i want fog on backside of model and not in front, i change distance in sketchup and move fog line on back, but after render, fog is everywhere. can you help me and give me any suggestions?
- fog.jpg (680.94 KiB) Viewed 6952 times
- Untitled fog.png (420.72 KiB) Viewed 6952 times
Re: Fog in Twilight render
Posted: Fri May 22, 2020 11:37 am
also i tried to turn off ''use background colour'' but it did not change anything
Posted: Fri May 22, 2020 2:55 pm
Melk-e-ART, please contact me via email at support@twilightrender dot com
Fog is not conntected to the depth rendering. You will have to change the appearance of the depth rendered image in photoshop using the "Levels" or "curves".
Posted: Fri May 22, 2020 3:05 pm
Thank you. i found, it was about GAMMA, i change it to 0.1 and it worked perfectly
Posted: Fri May 22, 2020 7:48 pm
by pbacot
btw where are you changing gamma? In postpro settings?
Posted: Fri May 22, 2020 8:16 pm
if you means this, yes. just gave it 0.1 and it worked well then in photoshop
- gamma.png (262.19 KiB) Viewed 6926 times
