Hi everyone! I bought the denoiser add-on to maximize the render time. However, when I turn it on, the render panel shows just a black image, without the model. Could you help me please? Thanks in advance.
Bye!
Render totally black with denoiser on
Re: Render totally black with denoiser on
Check the log (Extensions -> Twilight Render V2 -> Options -> Log). You may be exceeding your GPUs memory. If so, you can set a memory limit (also in Extensions -> Twilight Render V2 -> Options) for the denoiser.
Also check in options and choose a different image denoiser.
- Untitled-1.jpg (75.48 KiB) Viewed 5062 times
Hi Chris and Fletch! Thank you very much for your answers. I was rendering a huge image with 10+ Interior, so probably it was determined by a RAM problem. However, I finished it without denoiser and 190passes. For the other images, I change the denoiser preset as you suggested and I'll let you known. Thanks!
Have a nice day
Valcesura
Have a nice day
Valcesura
Users browsing this forum: Ahrefs [Bot] and 13 guests
