Hello Community. Thanks for taking a look at my rendering issue.
I've made a the ceiling in this model an emitter, and it's casting a strange pixelated light on the walls. I've tried several rendering modes (not all) and it seems to be a universal issue, which leads me to believe that it's a something within the material settings.
Thanks All.
Emitter render is wonky
Re: Emitter render is wonky
Welcome!
You should not intersect a light emitting object with other 3D objects in the scene. This will cause errors like this.
I you want a general soft illumination coming from above, delete the ceiling and go into the Environment editor, disable the sun and set sky type to "Sky Color" and set sky color to light grey.
Also with large light emitting surfaces like yours, it may render ok with Easy09 render setting, but with lower settings it will look bad, as you have shown.
- Untitled-1.jpg (200.01 KiB) Viewed 4294 times
Users browsing this forum: Bing [Bot], Google [Bot] and 31 guests
