Hi,
I created a large model of a project I initiating. The project is done with a lot of details. As I mentioned, I am new to rendering. Using the Pro version, and following some of the advice got in a previous post viewtopic.php?f=11&t=11666 about using higher resolution gravel and metal net fence, the results are still not realistic enough. As There is a limit for 3 images per post, I will post in the next 6 replies the imaes of the outside rendering, hoping for some advice of how to improve the reality look of it.
All rendering are at 07. High+, resolution 1920x1080,, Camera Only. Enviroment is set to Sky Color, as I couldn't find an appropriate Image to be use by Spherical Sky.
Thank you.
Improving realistic-view of rendering
- SketchUp: 2017
- Enviroment & Rendering setup
- Screen Shot 2020-08-06 at 11.10.40 AM.png (69.68 KiB) Viewed 6939 times
- P2.png (1.7 MiB) Viewed 6939 times
- G1.png (1.71 MiB) Viewed 6939 times
- SketchUp: 2017
Re: Improving realistic-view of rendering
Here are some additional rendering results
- G2.png (1.77 MiB) Viewed 6938 times
- G3.png (1.5 MiB) Viewed 6938 times
- G4.png (1.48 MiB) Viewed 6938 times
- SketchUp: 2017
- G5.png (1.45 MiB) Viewed 6937 times
- Open.png (1.75 MiB) Viewed 6937 times
- FP-F1.png (1.54 MiB) Viewed 6937 times
- SketchUp: 2017
- FP-S1.png (1.98 MiB) Viewed 6936 times
- FP-S3.png (2.06 MiB) Viewed 6936 times
- D1.png (1.37 MiB) Viewed 6936 times
There are 6 essentials to a good rendering. Please follow the 6 essentials tutorial video series linked in my signature. It covers all the areas of learning rendering. Rendering a model is not magic, it takes time to learn the technical skill.
You will need a much better ground texture/environment for a more realistic result.
