I'm wondering if it's possible to estimate needed rendering time for Easy-High presets (maybe based on Prelim. speed?). It would be really nice to have a estimation before choosing. I was in the situation to render Easy+, then Medium+, and finally to go even on High because first two did not shown as I expected. So first two renderings were just time waste and I did that exactly to save time . So, if we could have a time estimation, It would be more easier to choose best time/quality preset, without too much experimentation.
Also, for progressive can be estimated the time needed to achieve a certain number of passes? (I usually use 100-300 pass, depending on scene).
A way to estimate render time?
ARTIST AND DESIGNER DEREI.UK
Re: A way to estimate render time?
With progressive, it's linear - so let it go through 5 passes, and divide by five. Multiply the result by 100 for time to get through 100 passes.
Due to AA time being a complete wildcard it is basically impossible to predict render times for Easy 1-7 as far as I'm aware.
So, AA for Easy can't be used to extrapolate AA for High+, for example? There is no way to "guess" how long will take a better AA, if we know how long lasted the most basic one(or some other significantly lower setting) ?Fletch wrote:Due to AA time being a complete wildcard it is basically impossible to predict render times for Easy 1-7 as far as I'm aware.
If I'm not mistaking, I remember a friend of mine used Vray and there was a total time. He always knew when the rendering will finish.
This capability, while much desired, does not currently exist in the render engine. sorry!
No, knowing the AA time for a low render setting can not ( I don't believe) help extrapolate the render time for "High".
However, we could run some experiments and see if we can come up with some sort of "rule of thumb".
well, we know for for Progressive. Thank you, It really helps me.
Say I'm using Easy 5 for a ~900px preview size render.
Would it be appropriate to estimate ~4x longer for a 3800px render? Or am I over looking something?
JDZYN wrote:Say I'm using Easy 5 for a ~900px preview size render.
I think I am overlooking something... we're considering "area to be rendered"
So it would be about 16x longer? (!?!?!?)
889,249px in 943x943 image "A"
14,440,000px in 3800x3800 image "B"
B/A = 16.23842140952647
so a 2h21m render upsized would take ~38h17m !?!?
Guess i'll be using Easy 3 for the final. :/
This is not linear - so a finish time for your rendering can not be extrapolated, or intelligently calculated or guessed, by knowing the render time for a lower resolution and lower render setting, as far as I am aware.
Fletch wrote:...
Fletch wrote:...
No, knowing the AA time for a low render setting can not ( I don't believe) help extrapolate the render time for "High"...
Users browsing this forum: No registered users and 53 guests
