sketchup 2015
Re: sketchup 2015
After the conversion, check your log (Twilight V2 -> Options -> Log). Most likely the libraries that contain those materials could not be found. Make sure you have placed the libraries you are trying to load in C:\ProgramData\Twilight\Materials.
Note that there is a bug that has been addressed and will be fixed in M2 where material libraries in nested subfolders (like C:\ProgramData\Twilight\Materials\GroupOfMaterials\MaterialA) will not load for conversion correctly. We have fixed this but the workaround is to copy all the material subfolders to the C:\ProgramData\Twilight\Materials folder.
- SketchUp: 7
Re: sketchup 2015
a materiel is placed in my librairies of TWL 1
- Capture2.JPG (193.39 KiB) Viewed 8920 times
- 242424.JPG (39.35 KiB) Viewed 8920 times
ramy_ramroum
Re: sketchup 2015
You have it in the SketchUp 2014 folder. It won't be found by 2015 because it's not the same version of SU.
Place the libraries in the location mentioned previously.
- SketchUp: 7
Re: sketchup 2015
The prevuous picture its a picture of a matriall file of twilight V1 in sketchup 2014 so i can do the conversion to twl V 2 in SU 2014, But when i tried to install twilight V1 in sketchup 2015. I got an error while lanching sketchup.so i cant do the conversion to tw V2 in SU2015
ramy_ramroum
Re: sketchup 2015
You don't need V1 in 2015. Just copy the material libraries to the folder I pointed out.
- SketchUp: 7
Re: sketchup 2015
i don't have material files in program data
Should i copy it here C:\Program Files\Twilight Render 2\Legacy ?
- Capture.JPG (86.53 KiB) Viewed 8907 times
ramy_ramroum
Re: sketchup 2015
You can do that, yes. However, I would recommend just creating the Materials directory.
- SketchUp: 7
Re: sketchup 2015
I copied the files in a folder of my dropbox to keep all workstations updated.
I think this seems to work so far!?!?
