Sometimes I get yellow artifacts on random surfaces when rendering a scene @ 07. High+ quality.
Same scene/light settings/etc renders fine@ lower quality settings.
In this case, I went from rendering @ screen size High+ to rendering 4800px x image.
But it's happened in the past where I'd change from 05.Medium+ to 07.High+ without changing resoluion.
Maybe stop trying to multi-task?
Yellow Faces
Yellow Faces
- FC Model Good_Scene 9 -in progressWM.jpg (87.58 KiB) Viewed 6548 times
Re: Yellow Faces
Can't say I've ever seen this problem before.
My first guess is that it's a RAM issue.
Are you using 64bit SU and 64bit Twilight?
What are you machine's specifications? (?RAM)
If you save the file, restart your computer, and render again on Easy 07+ without any other programs open do you still get the same error?
Re: Yellow Faces
There have been a couple reports of a pale-whitish band horizontally across a render, but it only showed up in reflective surfaces (I think). I have definitely never seen a yellow band before... that is really weird. Is it repeatable or it just happens randomly?
I suspect it may have something to do with the sky image, as the band seems to line up across the horizon. What background type are you using?
Re: Yellow Faces
8GB Ram and a 64Bit OS... though I don't know if I'm using those versions of the programs.Fletch wrote:Can't say I've ever seen this problem before.
My work-around was to render at easy 05 Med+ .... the results were more than adequate.
Re: Yellow Faces
This one uses a simple white background color sky.Chris wrote:There have been a couple reports of a pale-whitish band horizontally across a render, but it only showed up in reflective surfaces (I think). I have definitely never seen a yellow band before... that is really weird. Is it repeatable or it just happens randomly?
The band stops there because that is where I aborted the render.... 50+minutes into it :/
It did repeatedly happen on a different file. Again, my work-around was to use a lower quality setting, which again, turned out more than adequate.
Re: Yellow Faces
As you can see, the 05 Med+ was more than sufficient!
- Plaza Mariachi Rendering WM.jpg (111.19 KiB) Viewed 6538 times
Re: Yellow Faces
Definitely an odd problem. If you come across it again, especially if it can be repeated exactly, let us know so we can look into it.
Users browsing this forum: Bing [Bot] and 39 guests
