What is the difference between Low and Low+ (as an example)?
Is there something I can read/watch that will help me understand the difference in rendering presets?
Render Preset
Re: Render Preset
Low - lower antialiasing level, lower surface fuzzy tracing, lower reflection threshold, good soft shadows.
Low+ higher antialiasing level, higher surface fuzzy tracing, fine soft shadows, higher reflection threshold.
Re: Render Preset
These tutorials are from V1 but still apply, but now with V2 you can more easily edit your render settings within Twilight now - no need to edit in external text editor.
Render Settings Tips
Re: Render Preset
Please note, the ability to edit presets in the Twilight Render XML editor is a Pro-only feature.Fletch wrote:These tutorials are from V1 but still apply, but now with V2 you can more easily edit your render settings within Twilight now - no need to edit in external text editor.
Re: Render Preset
Ah, yes, correct.
But one may still edit the presets manually with a text editor, as shown in the V1 Best of Tips and Tricks.
