Output size consistency
I have a problem that is driving me nuts. I do a render and bring it into Photoshop for post processing. I do not resize it in any way. If I go back to make revisions at a later time and use the same settings as the original rendering it never lines up with the original. The output is based on the size of the monitor and the toolbars filling the workspace. Is there a way to guarantee you are outputting the exact same size when you come back to make a revision a month later?
Re: Output size consistency
Yes. Uncheck 'Fit to View Proportions'. This will render the exact pixel dimensions set.
Yes, but the output is still based on the Sketchup viewport size and proportions, correct? In other words, if I mistakenly rendered the original with the Sketchup screen not completely maximized I will get a different result if I render again maximized. Or I render on a second monitor with different proportions from the original. Is there a way to lock in the size in those cases? Or do I have to make sure I have everything exactly the same each render? Thanks.
This might help:
Sizer is a freeware utility that allows you to resize any window to an exact, predefined size
http://www.brianapps.net/sizer/
There is another version in the Sketchup extension warehouse, I can't think of the name, so you might have to dig around.
**found it http://extensions.sketchup.com/en/conte ... rt-resizer
I use sizer, works great.
Glenn
Glenn
Nope. If you uncheck 'Fit to View Proportions' your render will always be rendered the same. Now, if you move your viewpoint it will obviously be different. But if you get the viewpoint you want and create a Scene for it, the position will be saved and you can easily restore it by clicking on the scene tab.jimn1619 wrote:Yes, but the output is still based on the Sketchup viewport size and proportions, correct?
Please watch the video tutorials, this is incorrect.jimn1619 wrote:Yes, but the output is still based on the Sketchup viewport size and proportions, correct? In other words, if I mistakenly rendered the original with the Sketchup screen not completely maximized I will get a different result if I render again maximized. Or I render on a second monitor with different proportions from the original. Is there a way to lock in the size in those cases? Or do I have to make sure I have everything exactly the same each render? Thanks.
As Chris said, the SU output and the Twilight output should match perfectly - if you are rendering from a scene tab view.
- SketchUp: su pro 2017
I agree with Glen Co.
Try the Eneroth Viewport Resizer free extension for SU.
I was having the same problem as you to find the same proportion of an old rendering of a projet.
That happened to me when I upgraded SU or Windows or monitor size.. The toolbars didn't have the same size... so the viewport size.
The plug in allow you to enter the size of the viewport.....
Hope that will work you.
Users browsing this forum: Bing [Bot] and 36 guests
