V2 Pro Video Tutorial Series Scenes
SketchUp: 2013-20
Post by Fletch » Thu Apr 11, 2019 8:29 pm
Here are the scenes (SU15 format so that most people will be able to open them into SU2015-SU2019) which are featured in our Tutorial Videos on Youtube. #videotutorials
:arrow: Get "Getting Started.skp" file here: :arrow: :arrow: Download "Complete.skp" file here.
SketchUp: 2013-20
Re: V2 Pro Video Tutorial Series Scenes
Post by Fletch » Thu Jun 27, 2019 12:32 pm
SketchUp: 2013-20
Post by Fletch » Tue Sep 03, 2019 6:38 pm
SketchUp: 2013-20
Post by Fletch » Mon Jan 06, 2020 2:24 pm
Here are the links to the lighted night scenes.
Scene Option 1 From the practice in the video:
Barcelona Pavilion Night Scene from video with Downlights and Box Wall Sconces
Scene Option 2 from the "final" exterior render with the dramatic lighting seen at the beginning and end of the video: (rendered in video with Easy09)
Dramatic Lighting Scene with optional lit with Spots or Emitters
In this scene, click the tab for Easy 09, render with Easy 09, this is the version mixing spots and emitters. Click the tab for Easy1-7, it hides all emitters and adds the spots which replace the emitter planes so that it will render relatively quickly with Easy 1-7. Actually this is a complex lighting situation that can take a long time to render. For the best results with quickest rendering time vs quality with the Photon Map render settings (Easy 1-7) try the one under "Advanced>AlternativeAA>02c."Low_AA3_Fine"
BarcelonaPavilion_MiesVanDerRohe_TwilightTutorialComplete-NIGHT-Spots-vs-Emitters_Lights-Easy09-1h20mDNZ.jpg
BarcelonaPavilion_MiesVanDerRohe_TwilightTutorialComplete-NIGHT-Spots-vs-Emitters_Lights-Easy09-1h20mDNZ.jpg (298.81 KiB) Viewed 2214 times
Before you render - Don't forget :!: :idea: :!: to load the free night-time Spherical sky for this tutorial found in the zip file download link above. Go to Twilight Render Environment dialog and browse to the sky image "Spherical-Treeline-Lake-Pano-Sunset2-dar.jpg"
Use this in place of the sky seen in the video tutorial.
After the image is rendered if you bring it into a photo editor, like Photoshop, try a simple "pop" of contrast with a curves adjustment layer like shown here:
SketchUp: 2013-20
Post by Fletch » Wed Apr 15, 2020 2:50 pm
:>: Download the Practice Scene to follow along with video tutorial.
If you wish to follow along you must download the same Flemish brick texture pack from Poliigon.com.
Chair Loft-TextureTutorial-Render-1920x1080.jpg (900.06 KiB) Viewed 1223 times
:ugeek: Download this Scene for Final Rendered Image of lone chair in front of brick wall (you must download the brick textures and open the Deep Material editor to direct all texture paths to your downloaded 3K images from Poliigon.com for the brick wall to work properly - which means you will need Twilight V2 Pro to edit the Deep Material for the wall.)
Video tutorial How to use high resolution PBR Textures with Twilight Render
(Specular, Gloss, Displacment, Normal texture maps)
SketchUp: 2013-20
Post by Fletch » Wed Jun 10, 2020 7:13 pm
