- Subject: V2 Tutorials Animated Snippets #glassmaterials
- Subject: V2 Tutorials Animated Snippets #Procedurals
- Subject: V2 Bathroom Tiles using Brick Procedural Texture
- Subject: V2 Ocean / Sea at Sunset
- Subject: V2 Tutorials Animated Snippets #emitter #striplight
- Subject: V2 Tutorials Animated Snippets #bevel
- Subject: V2 Tutorial #TV #Monitor #Display
- Subject: V2 Tutorials Animated Snippets #importmaterials
- Subject: Color Bleed (Bounced Color) and Material Saturation
- Subject: V2 Tutorials Animated GIFs #gif #GIF
- Subject: V2 Tutorials Animated Snippets #DeepMaterial #Shatteredglass
- Subject: Curtain Transparency by Alvydas - Deep Material Editor
- Subject: Using the Advanced Templates (v2.5)
- Subject: Translucent Material comparison
- Subject: Leaf Transparency
- Subject: Normal Map in Deep Material Editor in V2Pro
- Subject: Logo on glass
- Subject: UV Unwrap (v2 Pro)
Subject: Lighting and Render Speed (spot light vs light emitting surfaces (lem) in cove light / concealed lights
Light - a detailed tutorial for starting out in general with lighting in 3D by itchy animation
Animation Tips
Subject: V2 Tutorials Animated Snippets: #Animations
Environment, Sun, Sky
Subject: V2 Tutorials Animated Snippets #sunsky #environment
Subject: Shadow Catcher or Sky Projection Mapping
Subject: Background Image / Picture Using Alpha Mask
Forum Tips
Subject: Upgrade your forum account
Proxy Objects / Proxy Components
Subject: V2 Tutorials Animated Snippets #Proxycomponents
Subject: Twilight V2.14.1 FBX imported trees
Options
Subject: V2 Tutorials Animated Snippets #options #hardware #acceleration
Subject: Diagnostic Report #Diagnostic #report #log
Rendering
Subject: V2 Overlay Rendering with SketchUp View Image #overlay #composite
Integration of Twilight Render with other SketchUp Plugins
Subject: Create a Lush Grass Lawn with Skatter Plugin #Skatter
Subject: Get terrain model for your project
The standard SketchUp Plugins root directories are:
Windows SU8: C:\Program Files\Google\Google SketchUp 8\Plugins
Windows SU13: C:\Program Files\SketchUp\SketchUp 2013\Plugins
Windows SU14: C:\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
Windows SU15: C:\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
Windows SU216: There are 2: C:\ProgramData\SketchUp\SketchUp 2016\SketchUp\Plugins
~and~
C:\Users\your user name\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins **
Windows SU2017: There are 2: C:\ProgramData\SketchUp\SketchUp 2017\SketchUp\Plugins
~and~
C:\Users\your user name\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins **
Windows SU2018: There are 2: C:\ProgramData\SketchUp\SketchUp 2018\SketchUp\Plugins
~and~
C:\Users\your user name\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins **
(**Twilight Render uses the first one which installs for everyone who uses the computer. The second installs only for the current user.)
Mac SU8: Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/Plugins
Mac SU13: ~/Library/Application Support/SketchUp 2013/SketchUp/Plugins
Mac SU14: ~/Library/Application Support/SketchUp 2014/SketchUp/Plugins
Mac SU15: ~/Library/Application Support/SketchUp 2015/SketchUp/Plugins
Mac SU16: ~/Library/Application Support/SketchUp 2016/SketchUp/Plugins
Mac SU17: ~/Library/Application Support/SketchUp 2017/SketchUp/Plugins
Where '~/Library/..." is the same as "/Users/<your_mac_user_name>/Library/..."
Also, OSX has a habit of hiding the ~/Library folder (to protect mac users from themselves, apparently). So here is how to find your library folder if it is missing.
