How would you do this light.
Posted: Sun Aug 18, 2019 2:43 am
by pbacot
How would you set the light value and shade for this light? I have it set a little low as it was mostly decorative for the scene but I was surprised how low I had to set it to keep it from being overwhelmingly bright. How would you set real world parameters without it being too bright? Somehow it didn't seem equivalent to other lights I am using. I even tried an IES setting and that was surprisingly hot-bright. Also I added an emitter for the shade, while starting with a translucent shade default template.
Here it is in a test scene:
- Cabinet 19-8-16_sideboard.jpg (1.67 MiB) Viewed 17701 times
Just curious. I think it's OK as it is for my purposes. Thanks1
Re: How would you do this light.
Posted: Tue Aug 20, 2019 2:07 pm
pbacot wrote: ↑Sun Aug 18, 2019 2:43 am
How would you set the light value and shade for this light? I have it set a little low as it was mostly decorative for the scene but I was surprised how low I had to set it to keep it from being overwhelmingly bright. How would you set real world parameters without it being too bright? Somehow it didn't seem equivalent to other lights I am using. I even tried an IES setting and that was surprisingly hot-bright. Also I added an emitter for the shade, while starting with a translucent shade default template.sconce (rasmussen).skp
Subject: Translucent Material comparison
The emitting surface for the lampshade glass works great visually, but it renders very slowly unless you set type of Emitter to "Fake" so that it appears to emit light but does not do so. Then it will render quickly on Easy 1-7. It still emits light with Easy 09 or 10.
Posted: Tue Aug 20, 2019 5:22 pm
by pbacot
Thanks. I only remembered that the emitter would not slow down easy 09 , but I guess there is no reason for the shade to emit in this case. I adjusted the shade down and the lights up to get the appearance of the light source behind the shade,
- sideboard.png (5.5 MiB) Viewed 17673 times
Now I guess I need to get some things to put on the shelves! (I don't know what they --owners and ID-- want them for. Maybe it's a modern tokonoma.)
Posted: Tue Aug 20, 2019 5:33 pm
by ntxdave
Looking good..
Posted: Wed Aug 21, 2019 5:14 am
by pbacot
Thanks Dave!
