plaster material
- SketchUp: 7
plaster material
i took this picture from kerkythya gallery and i need a wall texture please!! can you help me ?
- m-GRECE.jpg (48.66 KiB) Viewed 18827 times
- ok_209.jpg (44.5 KiB) Viewed 18823 times
- normal_casolare_158.jpg (34.72 KiB) Viewed 18824 times
ramy_ramroum
Re: shearch material
Here you have the "original" material posted by Ciccio (the author of the last two renders), a bit low res though (anyway I think there is a lot of post pro involved). I've also attached a couple of mats I've made: a low-res previews and the links for high-res maps (diffuse+normal+specular). Let me now if they work for you, because I have many others plaster mats. Hope it helps.
:>: http://www.box.net/shared/uhxqzr7s4t
:>: http://www.box.net/shared/u7z3sm4irn
- Ciccio's texture
- calce.jpg (67.31 KiB) Viewed 18813 times
- My texture - low res
- intonaco_bianco_rozzo_2_DIFFUSE.jpg (224.99 KiB) Viewed 18819 times
- My texture_2-low res
- OpenfootageNETWalls02 copy_bianco.jpg (229.52 KiB) Viewed 18817 times
- SketchUp: 7
- SketchUp: 7
i use the normal map in the bump channel of the material tool of twilight render ?
ramy_ramroum
To use a normal map with Twilight, you need to create the material using Kerkythea (free) material editor, save it as a library, and load the material in Twilight as a library.
- SketchUp: 7
Ramy, I've assembled a library of white plaster for exteriors mats. The ones called "exterior white plaster" are physically accurate, while the ones called "calce" are made with Ciccio's settings and are not completely physically accurate, but maybe they will work for you. The ones called "rough exterior white plaster" have also a procedural added as bump.
Now the problem is that due to high-res maps the zipped folder is 47 MB . So maybe if you like one or two in particular I could do a smaller library or I could split it because box.net allows 20 MB max.
Anyway an easier way could be using Twilight templates and the specular map as bump map: you can also change the saturation, contrast etc. of the map in order to achieve different results.ohh i don' know to use it !!
- preview.jpg (359.65 KiB) Viewed 18713 times
- SketchUp: 7
Re: plaster material
thaaaanks massimo
i like calcce 02 and rough exterior white plaster 01
ramy_ramroum
Here you go.
:>: http://www.box.net/shared/xnsycyj5pb (18 MB )
Users browsing this forum: No registered users and 40 guests
