Aga/oven range.
Aga/oven range.
Another of the old home items which I will play with textures on. An oven range of the kind fitted when the house was built in 1865. The hdri is irrelevant, just a test.
- Meh.
- 1 9 60 Passes 36m Ir 0 a R.jpg (106.21 KiB) Viewed 5278 times
- SketchUp: Make 2017
Re: Aga/oven range.
Those are made from cast iron right? Because in the render it looks a bit too smooth, you should add a bump map to it. The texture in itself isn't bad tho.
Andrew F
Re: Aga/oven range.
Ta mate but not happy with it myself. There is detain that just does not show in the render AND, how much rust would there be on a working unit regularly cleaned? Finding a decent texture that works is a pain but the detail may just have to be emphasised by overscaling.
Re: Aga/oven range.
There could be some rust down at the bottom and at the grill where you put the fuel in, but other than that I think it would be rather clean. As for the texture, since it's pretty uniform you could try creating a procedural texture for it, I've not messed a lot with them but the results seem to be pretty good.
Andrew F
Re: Aga/oven range.
OK, changed texture, the background was just for light hdri. Still coming up with not quite it yet.
- Still looking...
- Classic Oven Range Ir 0 a R.jpg (106.89 KiB) Viewed 5176 times
Re: Aga/oven range.
Like where you're going with this Mike. Would be great to see it in context of a kitchen of the period.
Users browsing this forum: Bing [Bot] and 62 guests
