Hi All,
Just posting a render I made using TW of a model I came across when browsing around the 3D warehouse...
It's the Black and White Bedroom model...
I added a few plants, which I took from Solo's garden pack 1...
Hope you will like it...?!?
3D Warehouse model...
- BW-Bedroom-TW-06b-bloom.jpg (577.76 KiB) Viewed 13485 times
Kim Frederik
Twilight Render Support
Kim Frederik
Re: 3D Warehouse model...
just saw this here now... sorry for writing on it at KT forum, Kim.
as I said there I think it's very good! (considering it's a warehouse model)
I see that the phone mat. needs to be shiny plastic.
The floor mat. I mentioned needs some specular.
some other nit-picky things...
but considering the source, it's a great render! I love the glass light bulbs!
No need to apologize for anything, Fletch...
Here's another where I changed a few mats...
If anybody is interested in this scene, prepared for Twilight, please let me know and I will be happy to make it available...
- BW-Bedroom-TW-06c-bloom.jpg (649.29 KiB) Viewed 13415 times
Kim Frederik
Kim Frederik
looking good... except the foreground plant... to take care of it, I'm thinking some DOF?!
set the cam's focus target with right-click Twilight menu and set F-number in Camera tab to 2.8?
(if you set target you must use that resulting camera angle, clicking a previously made tab will negate/invalidate your camera's new focus.)
then when you re-render I think it will have much more realism. I was about to post-pro it... but decided to just have you try it with Twilight since it can be done "natively".
also, with the mat, it seems to miss some bump/specular. set it to template of at least rough stone and tweak from there... or use polished stone and back off the reflection if need be. Then use a large bump map to give some very subtle variations/ripples to the reflections.
*edit*
image added for explain...
in post pro the thing is these days to add a bit of vignetting...
I fudged the DOF in pshop and the reflections... which are poorly done here, but they get the point across I think.
I have the PSD if you'd like to see it.
*edit*
- BW-Bedroom-TW-06c-bloom-sf.jpg (129.52 KiB) Viewed 13407 times
Reason: I'm crazy like that.
I haven't seen your update on this, Fletch...
But I fully agree that the DOF adds a lot to this scene...
Kim Frederik
Kim Frederik
I think you did a great job.
DOF would be easy for you to set up. And I'm sure you know how, but in case others are curious how easy... I created this tutorial on using DOF in Twilight Render.
I would try it, but sort of have my hands full for the moment...
Users browsing this forum: No registered users and 64 guests
