Hi all
I am part way through modelling a very accurate rendition, please see the render below.
I would be interested in thoughts of poeple and in particularly the lights as this is critical for the job. To do the lights I have used ies files which were traken from the lighting company that was using the lights.
Any feedback appreciated!
Thanks.
modelling a room with accurate lighting
Re: modelling a room with accurate lighting
I am interessted in the glow of the outside light. Is it postprocessed or rendered?
- SketchUp: Make 2017
Hello, and welcome to the forums!
I'm guessing that the website the image links to is where you got the IES files?
The rendering is pretty good as far as lighting goes, altho I would either reduce the exposure so that the bloom from the outside isn't as overwhelming, or close the curtains so you can see the lights better. Just my thoughts tho, if that is the look you are aiming for then that's ok .
I have to ask however, is that a rendering you made or is that a reference to what you are trying to achieve? I'm asking because it doesn't look like a result Twilight Render would produce. I also found a video of the exact same scene on YouTube, in a graphics tech demo of UE4 from 2014. So idk there...
Andrew F
I like it, goes to show real as opposed to architectural lighting.
Great progress so far!
A little dark in bottom right corner on my screen.
I don't know about the quality of those particular lights but you will get some less desirable patterns on the wall, when the fixtures are so close. Often people use wall washer fixtures a little further away from the wall. Design wise it is also tricky with the seating right there, as people don't want to see the glare or be in a spotlight. The light on the sofa looks very bright and these same lights may work fine like this on a dimmer setting.
Users browsing this forum: No registered users and 48 guests
