Sun Room
Posted: Thu May 21, 2020 9:56 pm
by tuna57
Been away from SU and Twilight for months. Figured I'd better break it back out before I forgot what little I've learned.
Bashed together a little sun room scene. Rendered easy 9, 100 passes, minor post pro.
Re: Sun Room
Posted: Fri May 22, 2020 3:27 am
by pbacot
The light in the room and all is very real and looks great. The exterior is not as good as the rest, which is fully realistic IMO.
Re: Sun Room
Posted: Fri May 22, 2020 2:56 pm
+1 - definitely replace the background image. otherwise - very good!
Re: Sun Room
Posted: Fri May 22, 2020 4:48 pm
by tuna57
pbacot , Fletch , Thanks for the input. Agree the outside image could be a lot better. Used a spherical sky thats not to great. Really didn't want to go the route of "gimping" in the background. Probably will do some more experimenting with this one. cheers :!
Re: Sun Room
Posted: Sat May 23, 2020 10:01 am
by Mike1158
I agree with ^ but the room is nicely brought out in this, new background and it would be perfect. :clap:
Re: Sun Room
Posted: Sat May 23, 2020 7:32 pm
by tuna57
Thanks Mike. Posting a new render of this.... Swapped in a different spherical background image. Decided to turn out the lamp, got to save on the electric bill don't you know. Post pro Topaz and Affinity. Wouldn't mind to desaturate this particular spherical background image a little. Need to remember to take it into Affinity for some adjustments. Cheers !
Re: Sun Room
Posted: Sun May 24, 2020 6:23 pm
by tuna57
Last version of this I promise. Opened the background spherical image in Affinity , selected only the grass and desaturated it quit a bit. Tweaked the color of the lampshade a small amount . Also plumped up the pillows in these last two renders. Render settings stayed the same throughout. Fun practice to get back into the swing of things. Post pro
Topaz DeNoise and Affinity. :^:
Re: Sun Room
Posted: Sun May 24, 2020 8:48 pm
by pbacot
Good calls. Excellent!
Re: Sun Room
Posted: Mon May 25, 2020 8:59 am
+1 :gj:
the models of the pillows are not at the same level of the other furniture models, IMHO. :|
Have you seen these? Free for Pro users: Pillows and Wicker / Ratan Ottoman "Poof"
Re: Sun Room
Posted: Tue May 26, 2020 3:44 pm
by tuna57
pbacot , Fletch , thanks for your input and I agree I need to refine my pillows some more , I'll end up with really good ones one of these days if I keep work at them. :^:
