Testing of urban rendering
- SketchUp: Sketchup 2020
Hello there. i post first result in process testing. im so close to the end.
i used wet asphalt material from your library, but i have one ask. how can i get more reflective (more clean reflection) in wet area? Thanks
Re: Testing of urban rendering
Hello Melk-e-art!
Open material in deep editor and reduce strength of bump.
This is showing how to change the scale of the water, but it's an example of how you can edit the material in the deep editor.
Fletch yes but this is not what i mean. i tried many ways but can not find how to change reflaction. i want to get more highly reflective wet places
Try thisMelk-ART-e wrote: ↑Wed Nov 18, 2020 6:55 pm Fletch yes but this is not what i mean. i tried many ways but can not find how to change reflaction. i want to get more highly reflective wet places
http://twilightrender.com/phpBB3/viewto ... 9f3#p36486
Wow. looks very promissing.
alvydas
Try this
[/quote]
Alvydas Thank you. can you upload little tuttorial how to create same material? baceuse it looks like what i want yes, but i want to create my own material where will be used other high resolution realistic street floor with many reflective areas.
1) i am about this 2)this is what i create (this material i have from forum) and i just whant to increase the reflection (IOR) in some places.
how can i control it?
3) material i want to change and give it more reflection(IOR)
Try this
[/quote]
Select Reflection name heading and change IOR
- IOR.jpg (105.85 KiB) Viewed 10182 times
Alvydas Thank you. can you upload little tuttorial how to create same material? baceuse it looks like what i want yes, but i want to create my own material where will be used other high resolution realistic street floor with many reflective areas.Melk-ART-e wrote: ↑Thu Nov 19, 2020 11:32 pm alvydas
Try this
3) material i want to change and give it more reflection(IOR) material testing.png
[/quote]
You need to have multiple layers of texture. The texture of your pavement is almost one tone. It is difficult to separate multiple layers like bump or specular maps. I did something like that. If that option works for you, I’ll share how it’s done.
- test.jpg (626.07 KiB) Viewed 10157 times
- test11.jpg (1.66 MiB) Viewed 10157 times
Slight adjustment
- top.jpg (464.56 KiB) Viewed 10136 times
- top1.jpg (411.36 KiB) Viewed 10136 times
Users browsing this forum: No registered users and 18 guests
