Page 1 of 2
Steps with LED strip lighting under handrail (stairs / stairway)
Posted: Tue Jan 26, 2021 8:08 pm
Here's my quick WIP of this image someone shared here recently. This scene took me about an hour, maybe two, from start to finish.
MUST USE Twilight Render V 2.15.3 or later.
- 2steps.png (1.33 MiB) Viewed 21380 times
Feel free to open the attached SKP file and make your own changes/explore how lighting and everything was done.
Re: Steps with LED strip lighting under handrail
Posted: Wed Jan 27, 2021 7:52 am
by jo-ke
when I open your scene, the render is complete dark, even when I change the backgrundsettings.
It works for me very well, when I export the model in a new file
Posted: Wed Jan 27, 2021 1:03 pm
jo-ke wrote: ↑Wed Jan 27, 2021 7:52 am
Did you download and install the latest version of Twilight Render? My guess is that it's black because you have an older version of Twilight Render, and this is using the new ACES tone mapping algorithm.
Posted: Fri Jul 02, 2021 3:36 pm
by jo-ke
another question to light settings.
render in preset #9:
I would like to achive the attached photo
the light of the stripes is also lightning the scene (see at the drawers)
- light2.jpg (198.78 KiB) Viewed 18984 times
What setting should I use to get the same result in the render?
- light.jpg (165.6 KiB) Viewed 18984 times
Posted: Fri Jul 02, 2021 9:22 pm
The light strip should be a little wider according to your photo example, set to 500 watts and 13 lm/w .
Try a little "bloom" to get the "glow".
skippy attached.
it needs to be balanced with the light in the scene and the post-pro settings used.
Posted: Sun Jul 04, 2021 8:17 pm
by jo-ke
thank you. I've learned something new. bloom makes the diffenerce.
where can I find some documanation about the postpro settings?
Posted: Sun Jul 04, 2021 8:55 pm
by jo-ke
and the result:
Posted: Mon Jul 05, 2021 6:59 am
by alvydas
I like such a simple furniture system. The pants shelf is pulled out? I never would have thought of that. What are the profiles with the LED system here?
Posted: Mon Jul 05, 2021 12:13 pm
jo-ke wrote: ↑Sun Jul 04, 2021 8:17 pm
Post Pro Settings for Twilight Render Tutorial on the website
Posted: Mon Jul 05, 2021 1:36 pm
by jo-ke
alvydas wrote: ↑Mon Jul 05, 2021 6:59 am
The System is
www.cabinet.de Germany.
The pants shelf is to pull out
