- VillaSavoye-cor.png (1.55 MiB) Viewed 3592 times
Villa Savoye
Villa Savoye
Hello, model of 3d warehouse, Skatter grass and shrubs, easy 08, some perspective rectification in Xara designer. Twilight pro and denoise.
Re: Villa Savoye
It is looking very nice/clean. Very nice image.
To improve, may I suggest lowering brightness of the white walls, or even better finding a good quality plaster / stucco texture for the walls?
Adding some dirt/streaks will add even more realism.
- villa_savoye_59de896136042.jpg (92 KiB) Viewed 3578 times
Re: Villa Savoye
Some work on textures, light, and color temperature
Re: Villa Savoye
looking very good - worthy of the gallery there. Thanks for sharing, Moujik!
Needs some better foreground and background foliage to take it up even one more level.
Re: Villa Savoye
"Needs some better foreground and background foliage"
Yes, you're right. Landscaping is chalenging. Where to start ? Adding 2D in photoshop, or in the model ? I cannot find good free PNG cutouts, nor 3D trees. Buy some ?
Re: Villa Savoye
For foreground foliage, I took photos around my region and cut them out in photoshop myself. Then when I put it in the foreground give it a touch of blur to give a little depth of field effect. I also create my own spherical sky treeline images.
But of course there are many online sources as well, but you will need to spend time searching.
There are some decent 3D vegetation models out there if you do some searching on 3D warehouse and other 3D model supply shops online. Try starting here: https://www.vizpark.com/free-stuff/
Re: Villa Savoye
Users browsing this forum: No registered users and 58 guests
