Spring reading
Spring reading
The first version of the original Twilight Renders without correction. 09 easy, 10 minutes. The second use: TopazDenoise (remove noise), Picasa (contrast), Gimp (Lens Flare, and reduce image artifacts on the hide.)
- spring.jpg (711.7 KiB) Viewed 16457 times
- springdenoze.jpg (262.11 KiB) Viewed 16446 times
Re: Spring reading
Wow!!
Great image
Great image
Thanks n Rgds
Tom
Confucius
Tom
Confucius
- SketchUp: 15
Re: Spring reading
Awesome image I love this one
- SketchUp: SU8 to SU2019 Pro
Re: Spring reading
+1....!!!
Re: Spring reading
Thanks guys. Later I will put a higher resolution.
Re: Spring reading
no don't....or we will beat you up.....!!!
Re: Spring reading
Gareth wrote:no don't....or we will beat you up.....!!!
if anyone need high-quality books (not read-only), I can lend
- springsdenoise.jpg (713.17 KiB) Viewed 17092 times
- spring2.jpg (546.24 KiB) Viewed 16938 times
Re: Spring reading
I love the first view....fantastic. The last view lost some of the realism. It feels too "set up". The large block table on the left seems a bit out of place as well.
Scott
Scott
Re: Spring reading
This is the case here. I work on average, which is great. I started to try to do well and spoil everything . The large block table on the left for fun. But I agree with you. I lost my camera angle and all my work went in vain. Other results are not so good . Just this chair is my model (from Ikea), and the rendering is just an experimentScottPara wrote:I love the first view....fantastic. The last view lost some of the realism. It feels too "set up". The large block table on the left seems a bit out of place as well.
Scott
- SketchUp: 8
Re: Spring reading
I look the first viev too, very good job in postproduction to clean the image. Can you show you parameters or explain your workflow in Topaz? I can't ajust well in my works.
If you want, can lend a books for my renders.
Scuse for my english is not my languaje.
Users browsing this forum: No registered users and 22 guests
