Lving and kitchen
Lving and kitchen
working on some interior shots for a client, I had to create the pendant lights myself, they are glass but doesn't seem to show quite right in the rendering. Perhaps needs to be more reflective? comments welcome, thanks!
- interior living kitchen (2).jpg (372.12 KiB) Viewed 1484 times
- SketchUp: 2018
Re: Lving and kitchen
Do You have reference picture of this pendant lights ? If it's clear glass it looks quite good. You might be interested also with this topic Interior Renderings - Exposure for Background Outside
for small objects that are actual glass, like these pendants, it should be built to exact proper thickness for the glass, then apply realistic glass. for shiny glass use 1.8 - 2.2 IOR instead of default 1.52 IOR
the image overall looks great!
The black mullions on the window wall are too black, nothing like real life 'black'. Avoid anything darker than 85% grey... I think 80% grey is even better.
For the white paint on the cabinetry and wood trim around windows/openings/floor - try a slight edge line in the material
Template Material>Advanced>
+Weld Vertices
+Enable Edge Line
Hard Edge Angle 30 degrees
Edge Line Thickness 1,2, or 3mm <<need to test in your rendering... 1 is probably good. In Deep Editor you can specify the edge color to be other than black after you get your material set up as a template and you are happy with it, convert it to deep edit mode and change color of edge color if you desire.
+Weld Vertices
+Enable Edge Line
Users browsing this forum: Bing [Bot] and 24 guests
