Ocean House Project
Re: Ocean House Project
Thanks Fletch, I read that post about the pool water automatic and I could be wrong of course but are you sure it works that way on Mac. I still had to change settings according to the Quick Start Guide video to get the desired result.
Very, and I mean VERY nice, there could be better a better relationship between the sky visible in the roof lights/skylights and the sky.
I will rewrite that because I must have lost my train of thought or my mind. What I mean is the sky visible through the skylights/roof lights and the sky visible directly from the point of view origin.
Thanks Mike but that's not the sky your seeing in the skylights it's a texture/ emitter, there's actually a floor above what you see. as represented in this photo. I guess you would call it a suspended ceiling like in an office building. The sky is part of a Hires HDRI.found here
viewtopic.php?f=26&t=237
- Screen Shot 2017-05-16 at 8.27.55 AM.png (1.13 MiB) Viewed 12737 times
I get what you are saying but the texture did not reflect the sky above the building, there is a disconnect in textures. I may be talking out of my sofa but it looks a little, and I will reiterate this, a little odd to me.
I think the model and renders work well, it might just be my perception.
That last render is dogs danglies.
That's not the render it's the photo I was basing the SU model on.
I'm pretty new to nighttime and sunset renderings so I could use some C&C Thanks
- sunset.jpg (681.86 KiB) Viewed 12681 times
- sunset-2.jpg (716.87 KiB) Viewed 12681 times
a couple with post pro, I'm not sure which is better but I like the dark one
- Ocean House copy 6_front ISOa.jpg (622.72 KiB) Viewed 12635 times
- Ocean House copy 6_front ISOa copy 2.jpg (794.79 KiB) Viewed 12635 times
- Ocean House copy 6_front ISOa copy.jpg (902.75 KiB) Viewed 12635 times
very nice, Walt!
I like "copy2"
I like "copy2"
Thanks Fletch
Users browsing this forum: Bing [Bot] and 67 guests
