I was once again playing with Twilight's caustic effects, creating these for fun.
I added the volumetric light effects post pro in the window caustics image.
Renders with Caustics
- SketchUp: 15
- Glass_Rainbow_Caustics_Final.jpg (734.57 KiB) Viewed 4974 times
- Architectural_Caustics_01_SU_Final.jpg (392.48 KiB) Viewed 4974 times
- Architectural_Caustics_01_TwL_Final.jpg (1.11 MiB) Viewed 4974 times
Re: Renders with Caustics
the rainbow colors are good! Rendered with Easy 10? Which material did you use?
Are those glass blocks from Subject: Glass Block / Glass Brick ?
- SketchUp: 15
For the rainbow colors I rendered with Progressive 02 BiPT (probably easy 10 is faster?), material is the Glass>Common
The glass block I modeled and assigned SketchUp texture Water_Pool_Light. Then in Twilight assigned Glass>Common. Used SketchUp's
Sun and an HDRI which seemed to satisfy my idea for the exterior environment through the window.
I never thought to look and see if there was a Twilight glass block model/texture. I just had a look now and it looks better
than mine for sure.
than mine for sure.
Easy 10 is MLT/BiPT, so it's slower.
Users browsing this forum: No registered users and 83 guests
