Exterior Night Shots
Just completed this project today....
I was only given 5 working days to complete it
(3 days modelling+2 days texturing, lighting & Rendering)
as always time was not my friend
Just hope the client likes it......
anyways comments are very welcome...
Thanks again Twilight Render
- 1.jpg (581.88 KiB) Viewed 9629 times
- 2.jpg (423.45 KiB) Viewed 9629 times
- 3.jpg (939.84 KiB) Viewed 9629 times
Re: Exterior Night Shots
The other two....
- 4.jpg (662.67 KiB) Viewed 9626 times
- 5.jpg (897.48 KiB) Viewed 9626 times
From my perspective, those are great renders and show the project in a great light. Nice one.
Very nice - hope the client liked your efforts.
Very nice.
I think a little "boost" in post processing is often helpful.
- 5.jpg (856.64 KiB) Viewed 9598 times
- 3.jpg (1.2 MiB) Viewed 9598 times
Fletch, your enhancements are great also.
Now let me ask a dumb question. Why is it/or is it necessary to do post processing? I see this very often with a lot of different rendering packages. It seems to me that one should be able to make the same type of adjustments in the rendering process.
I do not do very much rendering but have wondered this for a good while.
You can absolutely change the tonal exposure of your rendering from within the render window.
Look up "tone mapping" here in the forum, I've talked about it extensively.
However, if you save the image, and close the render window, you can't tone map the image. Then post processing is necessary.
(Pro users can use the history to recall an image they've rendered within a session of SketchUp and still tone map and save the image.)
If you've ever taken a photo, you know that the exposure of the image is important. The exposure is essentially the control of the camera deciding how light the whites and how dark the blacks are going to be in the image. This is the same as tone mapping - tone mapping is controlling how bright or dark the different pixels will be in your rendering.
If you don't choose the ideal exposure/tone mapping settings during the rendering, you can often recover some of the "pop" as I've done in this example, buy adjusting the image in post-processing.
I did this in seconds using the Topaz Labs plugin for photoshop called "Adjust".
thanks for the comments guys......and as always Fletch thanks for the "boost"....
you know some clients just don't know the effort and time we 3d guys put in to projects....well that's just life
anyways I'm working on another set....I will try and post the drafts soon.......
Users browsing this forum: Amazon [Bot] and 29 guests
