SOLVED: autocad LT error aborting fatal error unhandled e0434352h Exception
Posted: Thu Nov 11, 2021 12:09 pm
Sorry for the off-topic of SketchUp and Twilight, but I'm putting this here for safe-keeping in case it will help anyone out there on the interwebs searching for an answer to this problem.
Error message from ACAD every time it crashes is something like this:
autocad LT error aborting fatal error unhandled e0434352h Exception at 5bb34b89h
Ok, so AUTOCAD crashing with fatal error unhandled e0434352h Exception appears to be solved!
The answer was unpredictable and weird.
In Windows 10 settings I disabled the text cursor indicator and returned the cursor thickness to normal default. ACAD stopped crashing! It hasn’t crashed today. Apparently Windows was fighting with ACAD to add these features to the cursor anytime I was typing in ACAD commands, but simultaneously I was drawing and it was getting confused what to do... causing a crash.
Read the full story only if interested:
I was trying to think of anything I changed lately that may effect autoCAD. I noticed that it crashed more the faster I tried to work. So the faster I typed my commands, then it would crash more often.
So then I remembered…
Lately my eyesight is not 20/20 like it used to be. So running double screens sometimes I find I lose where my mouse or cursor are.
I went into Windows system settings for the cursor and the mouse a couple of weeks ago and (foolishly) enabled “Turn on text cursor indicator” and increased the size of the cursor indicator as well as the cursor appearance which sort of acts as a “highlight cursor” feature.
This is what was apparently was causing ACAD to crash. Because after all the other major changes nothing changed and ACAD kept crashing (update ACAD, update graphics driver, update windows, yadda yadda).
But once I DISabled the text cursor indicator and returned the cursor thickness to normal default. ACAD stopped crashing! It hasn’t crashed today.
So annoying. How many hours of my life were lost to that weirdness?
Apparently ACAD and Windows could not figure out what to do with this cursor indicator when I was drawing and typing commands simultaneously.
Mystery solved.
Mystery solved.
