I know there isn't meant to be a limit on the V2 Hobby output image size, but I am having trouble getting anything more than a black rectangle out of an e.09 or e.10 internal progressive render of a scene when I try for an image size greater than 2048px wide. If I run it at 2048px wide, or smaller, then I immediately see light forming in the black after even only 1% of pass 1; but get nothing after a full pass 1 on any larger image sizes for the same model and scenes. It takes a while to run the passes, so I am loath to keeping it running overnight only to find I'm still left with a black screen - unless anyone can confirm that it will sort itself out?
I am using V2.2 32 bit Hobby on SketchUp Pro 2014, threaded x8 on an i7 3.40 GHz processor and 64 bit Win 7 Pro O/S. Is anyone aware of any specific limitations that could be causing the blackouts?
Thanks
V2 32 bit Hobby limit on image size?
Re: V2 32 bit Hobby limit on image size?
A 32 bit application is limited to less than 4GB of memory. Most likely you are running out of RAM.
Try reducing the size of any large textures in your scene.
Users browsing this forum: No registered users and 19 guests
