How Fast Are You - Official Twilight Scene - Bauhaus Lamp
Bob James
Re: How Fast Are You - Official Twilight Scene - Bauhaus Lamp
Post by Bob James » Fri Mar 26, 2010 9:42 pm
Downloaded your latest .skp version.
No render method chosen: 33 sec
Render method "Low" : 33 sec
Is this latest version different than the previous one? That's a pretty large change from 20 sec to 33 sec :shock:
Lamp - Low.jpg (122.46 KiB) Viewed 5354 times
If you don't think ahead you'll be at the mercy of those that do - Ashleigh Brilliant
SU 7.1 and Win 7
SketchUp: 2013-20
Post by Fletch » Fri Mar 26, 2010 10:42 pm
ah, much better! Well, not sure what happened. Glad the camera is set correctly. Thanks for the follow-up.
With the lamp occupying more pixels, there's more to anti-alias, and that is the process that can take a lot of time.
faluchdeviaro
OS: w7
SketchUp: 8
Post by faluchdeviaro » Wed Apr 07, 2010 6:05 pm
My test on W7 64 bits.
image attached by admin
paappleb
OS: Windows 7 64x
SketchUp: 8.1
Post by paappleb » Thu Apr 15, 2010 6:27 am
Well it looks like I am the first to submit some results using an AMD powered PC. What can I say, I like being a little different. :lol:
AMD Phenom II X4 965 Processor 3.4 GHZ
8.00 GB RAM
Windows 7 64-Bit
Twilight Test.jpg (396.98 KiB) Viewed 5264 times
Ecuadorian
OS: Windows 7 Pro 64-bit
SketchUp: 7.1
Post by Ecuadorian » Sat Apr 17, 2010 4:58 am
My results.
Solo
Post by Solo » Tue Apr 20, 2010 4:39 pm
I'm getting the same issue as Scott, I tried both the skp and zip but view is further away, not sure how to correct it.
I got 17s but it's wrong view.
SketchUp: 2013-20
Post by Fletch » Tue Apr 20, 2010 7:39 pm
clicking "Scene1" doesn't choose the correct view?
What screen do you have? This is done with a widescreen.
Solo
Post by Solo » Wed Apr 21, 2010 6:53 pm
I'm using 2x 42" LCD's in dual mode.
SketchUp: 2013-20
Post by Fletch » Wed Apr 21, 2010 7:11 pm
I guess, just do your best to get it close to same view as you can... :? I'm not sure what could cause this. Maybe it's an issue with screen resolutions or something? (doesn't make any sense)
ScottPara
Post by ScottPara » Fri Apr 23, 2010 10:49 am
I did not have an issue with the file. It worked correctly. I am running dual 30" screens and that did not effect correct results.
scott
Locked
