Marble Challenge
- SketchUp: 2014
Marble Challenge
I set up a "Render This" challenge at SUC for a marble. I wanted to add it here as well,
mainly because I am having the hardest time getting the glass to look right.
Here is a photo of some real marbles:
Attached is a model of a marble I made.
It is a bit different from the one at SUC as I have subdivided the surface one iteration so it is smoother.
Anyway, please post render and material settings so we (I) can learn from this. Have fun.
- Marble.jpg (72.28 KiB) Viewed 11868 times
- Marble.skp
- (366.18 KiB) Downloaded 509 times
Re: Marble Challenge
Eric,
Maybe people missed this little gem somehow.
It's so simple, yet a great "twist" on the the classic 3D sphere everyone seems to render at some point.
Hope this is a worthy entry.
You can open my scene and render.
You will need to browse and find the Apt-probe.hdr and place it in the sky slot and you will need to load the IES data file (provided in the zip below) into the light I have in the scene.
I actually had a lamp in there, but had to remove it from the scene before sharing, sorry.
- Marble-Boofredlay-renderchallenge.zip
- (477.97 KiB) Downloaded 526 times
- Marble-Fletch-Easy10-bloomvignette.jpg (105.39 KiB) Viewed 11736 times
- Marble-Fletch-Easy10.jpg (127.56 KiB) Viewed 11745 times
a couple others... NO PHOTOSHOP OR POST PRO.
It's basically the same scene you downloaded above - modified the marble a tiny bit.
copied and rotated the marble as a component. Then set focal point on center of marble, and render with Camera F-number on 22.
you can get the new swirly marble here:
- Marble-DOF_Easy10.jpg (85.58 KiB) Viewed 11681 times
- Marble-DOF-TWL_Easy10.jpg (37.1 KiB) Viewed 11677 times
- SketchUp: 2014
Updates...
Everyone must be quite busy ... no comments?
- Marble-TWL-Interior+_web.jpg (81.49 KiB) Viewed 11613 times
- Marble-Swoosh-Interior+_web.jpg (91.17 KiB) Viewed 11609 times
Dear Fletch, I'm always watching your work. it is difficult to comment on something. Because we ask for your advice. Thank you for sharing your experiences. And I really do not do better than you. Here I see a very good result . Question - can be better. I do not.
Thanks Alvydas.
I think just a post to tell someone "I like it" is always welcome... or "have you thought of trying this..."
Here's the file with the scene so that anyone can open the file, and play. This is the "swoosh" scene. (v SU8) (SU7 provided upon request) Remember that it has the Camera F-Number set to 22. To make it render faster in any setting you can make the camera a "Pinhole" type.
For such a tiny scene, it's quite complex and has a lot going on. (so it does not render lightning quick) All the refractions/reflections/caustics/DOF/IBL(HDR) lighting, etc. Did you notice the dual-refracted caustics on the yellow part next to the large bubble?
Remember to download the IES file (with the scene provided in my post above) for the light bulb. Also remember to download the free HDR and make sure to load that into your sky when you open this scene. Save the scene, and then hit render.
ok. Here is my attempt to
- marble.jpg (177.63 KiB) Viewed 11573 times
I really liked your results, Fletch...unfortunately I don't have time to try myself right now.
-Marcus
Thanks Dozr
Here's another one.
Alvydas, that's lovely!
Here's another one.
- Marble-TWL2-Easy10.jpg (35.42 KiB) Viewed 11555 times
- different gamma/tonemapping
- Marble-TWL2-Easy10-tonemap.jpg (76.09 KiB) Viewed 11551 times
Users browsing this forum: Ahrefs [Bot] and 15 guests
