Maintenance Release Twilight Render 1.0.6
The latest about Twilight
Locked
OS: Win10
SketchUp: 2016
Post by Chris » Tue Sep 01, 2009 3:05 pm
Hello All,
There is a new maintenance release available here, version 1.0.6.
In this release you will find:
  • A fix for background images not rendering correctly
  • An option to turn on and off the use of layer visibility in components
    • Right click on the component in question.
    • Select Twilight
      • To turn on and off layers for just this component, select 'Use Layers in Component' to enable layer visibility, 'Ignore Layers in Component' to disable layer visibility
      • To turn on layer visibility for all components, select 'Force Layer Visibility in ALL components'
    • Transparent TIF handling for clip mapping
    • Added button to Options->Dialogs to 'reset' the saved location of Twilight dialogs, like the render dialog.
Just install over the top of your previous installation. No need to uninstall first.
Locked
Users browsing this forum: Bing [Bot] and 0 guests
