Hello,
I want to do an experiment to have a rendered image printed on an 8x10 or a 16x20 sheet.
If we print at 200dpi or 300dpi, what dimensions would the render need to be set at?
For an 8x10 Glossy shot
8x300 = 2400 x 10x300 = 3000 so 2400x3000?
For a 16x20 Glossy shot
16x300 = 4800 x 20x300= 6000 so 4800x6000?
Am I on the right track?
Is this even possible?
Thanks
Resolution for Printing
- SketchUp: Version 8
Re: Resolution for Printing
your calculations appear correct.
300dpi is overkill. 150-200dpi is plenty.
the bigger the board, the more distant the observer, the lower the dpi (do you think they print signs at 300dpi?)
Subject: Render Size
Fletch wrote:300 dpi = glossy hi-res magazine
200 dpi = great 11"x17" presentation paper size
150 dpi = good 11x17 presentation paper size
72 dpi = web display or large format
18-50 dpi = very large format
see also miguel's tip for large format presentation.
300 dpi for large presentation is laughably ridiculous.
If the sign is 144" wide (12') 72x144= 10368 pixels wide. I think that will be quite a challenge for you.
4000 pixels I'm guessing is about what your RAM will handle (if that) with 32 bit rendering out of SketchUp. And the render could take a while.
I would suggest rendering at 3400px, blow just a small portion of it to the site sign actual size so that you can see a preview. Try the same also for 4000px.
Another great tutorial about presentation resolution.
Thanks Fletch.
Just wanted to have something printed that would look good hanging on a wall. A print so to speak.
Users browsing this forum: No registered users and 22 guests
