Hi everyone,
SK 2014 + TR 2 with easy 07 take 15 minutes each.
but I have problem with the grass... how I can make the realistic grass.
MAZE
Re: MAZE
These made me smile! Nice work!
Try the Twilight grass components. However, when you scatter the components using either the component spray tool by Didier Bur, or the fur plugin, you will need to render using Easy 09 or Easy 08 There will be too many grass faces for the Easy 1-7 settings to handle the mesh map.
Re: MAZE
Sorry Fletch, but where can one find the Twilight grass component? Many thanks.
Re: MAZE
availability of all your RAM will hopefully reduce/eliminate crashing
RAM does not speed up render times.
Users browsing this forum: Bing [Bot] and 19 guests
